Help! please!
4 Nov 2009
Port Glasgow
I think there is somthing wrong with my computer i went to go on crysis and when it was on server loading the screen went black and i had to restart my computer and when i restarted there was little squiggly lines all over the login screen and when i logged in the screen went black the comp restared and there was a little - up in the corner so i started in safe mode and there is 4 groups of blue or red lines down the screen. :( Whats the problem and how can i fix it :(?
Launch the game with Compatibility Mode: Vista Service Pack 2. Right click the icon, properties, etc.
its everywhere now i tryed my tv and still the same i cant even get to log in screen when starting the computer normaly:( i have to do safemode with networking :(
edit: had this comp for 3 years my 5770 comes tomorrow so last night i put some new thermal paste and cleaned out all of the dust with a hover and a brush started fine played games and now randomly today this has happend i hope its software related or the 8800. When i try to run startup repair or repair your computer the screen just flashes :(
Do you get any coloured lines or blocks when you are in the bios screen, if so i think memory chips on your gpu is borked.
At least you will have a nice new 5770 tomorrow to keep you gaming.
In dell bios there is black dots all over and the dell logo when you start the pc the dell logo is coverd with black dots.
Ran some tests on bootup screen mem ones are ok buy when i do the full system test i get loads of these errors..
Error code 5300:0119
Msg : Detect a failure when writing and reading video memory. Video mode Dh(320x200x16) adress A0084, expected to read FFFFFFFh but read Oh instead
The given error code and message can be used by dell technical support to help diagnose the problem.
So is it only my graphics card thats dieing because i cant boot into normal mode still only safemode with network.
ok just uninstalled nivida drivers and then restarted and got into the pc's normal mode but the lines are still going down the screen :(
Definitely a busted card. I'm guessing that the cooling has failed and the card has overheated damaging it. Happened to an old 9600XT I once had.
