Help please
6 Feb 2009
Redcar, Cleveland
Ok few problems:
I'm fitting the annoying as hell connectors to my MOBO (PW SW, HDD LED etc) and there are some i have no idea where to put.
1) I have two audio cables one labeled AC '97 and the other HD Audio then they have a load of single pin connectors coming off it. Which one do i connect? Also for the Power LED its quite a chunky one and cant see anywhere on the MOBO to put it.
2) Also have same problem with fan connectors. There are like 4 biggish pins.
Thanks
