Ok few problems:
I'm fitting the annoying as hell connectors to my MOBO (PW SW, HDD LED etc) and there are some i have no idea where to put.
1) I have two audio cables one labeled AC '97 and the other HD Audio then they have a load of single pin connectors coming off it. Which one do i connect? Also for the Power LED its quite a chunky one and cant see anywhere on the MOBO to put it.
2) Also have same problem with fan connectors. There are like 4 biggish pins. Noticed on my PSU there are connectors that will fit them, do i just slot the in here?
3) On the main power supply cable, (http://farm4.static.flickr.com/3534/3849042745_d8246338ef.jpg) i have 4 remaining pin slots, in that photo they are all full but on mine there are 4 left at the end. Do i just leave them?
Thanks
Thanks
