Help Please
Permabanned
29 May 2009
Ok i was just reading my manual and i was reading a little about TPU AND EPU onmy board, so i powered off turned them on and powered on. Checked the settings they gave me, then powered off turned them both off and powered on. Now i have the most annoying problem, my corsair h80 is going high low high low high low high low, over and over again, ive gone back to bios and made sure its on turbo like it was before. Ive tried a jumper reset and put settings on exactly what they all where before i used the silly epu and tpu controls. Now this is just annoying me, i cant put up with it. Any ideas guys before i crack up.
I would reset the CMOS again and load optimised defaults (rather than adding yuor clock) and see if it still does it then.
If that fails you could try removong the battery for 5/10 minutes just to be absolutly sure everything has cleared.
Ok mate i have just tried optimised defaults and its still doing it. I cant belive this. Asus adding there crap additions. i really dont want to mess with the battery tbh
It was fine before i pressed these stupid buttons. Ok the 2 fans are going into the h80, the h80 is plugged in via molex.
even when priming its doing it, its not staying at full speed
i plugged them into the board, they where fine, i plugged them back into the block and plugged the h80 into both the molex and the cpu fan and its working now. Never pressing TPU again
