help please
9 Dec 2012
newcastle upon tyne
hi guys im new to this fourm and also to building a pc so i was woundering if you guys could help me i wanting to build a gameing pc
and i want to to put a radeon hd 7850 gpu
and and an amd fx 8120 cpu
with 8gb of ram
but im nt sure what motherboard to go with
also if u guys could recommend a case these will be able to fit in
atb james
will that be ok for playing things like dayz call of duty and left for dead games
The i3 or the i5?
The i3 won't struggle with any games with the exception of the extremely CPU heavy games (bf3 64 man multiplayer) and WOW at high (all processors struggle then).
The i3 or the i5?
im not planning on playing any battelfield multiplayer as i play that on my console only be playing
dayz
l4d 1&2
tf2
The i3 or the i5?
hi what i5 is it you would say is best for my budget
Sorry for hijacking this thread too, was wondering, with the above rig, how easy is it to upgrade/improve and is there a chance if you were to buy separate components that it could be built for you?
im guess ing this would be easy to upgrade as he said just by an i5 in the future and would nt be to hard to build ur self
self builds are reasonably easy to put together as everything really only fits in 1 place or in 1 certain way. the difficulty however is when you run into problems, faulty ram, motherboards psu's etc. without spares or access to another system of similar spec you could be faced with the cost of returning parts to the supplier to be tested etc.
but simply switching out the likes of a cpu or gpu at a later date is pretty easy if you take your time
