Help please
17 Dec 2011
Okay I don't know if I'm completely screwed and excuse me if any spelling mistakes or anything as I am on my phone because my pc is broke and that's why I'm here haha :) , well I was just casually playing bf3 when I turned around in my chair because I thought somebody came in the room , I was just hearing things , but when I turned around my foot yanked the power cable to my pc and now it will turn on but not boot up I think I get 4 beeps fast then a single beep then another fast 6 beeps :
My rig is :
I7 [email protected]
Nvidia GeForce Titan ( why I'm scared haha )
I'm not exactly sure about my motherboard as I have all the specs saved on my Pc but it is a republic of gamers asus motherboard and it has the bios with mouse compatibility , that's about what I know about it haha
If you need to know anything else , just tell me , just keen to get this sorted
Open up your case and physically look at the motherboard, the Model Number will be there somewhere (maybe around the PCI-E x16 slots)
All I can suggest is that you strip it down to basics.
Use on-board VGA if available (remove the Titan) or even try a different card.
Use 1 stick of ram
Recheck all the cables to make sure they are still all connected.
With the power disconnected, take a screwdriver to the CMOS reset pins (near the Front Panel power connectors) and bridge the pins using the screwdriver for a few seconds.
Connect the mains, and try and boot.
If it fails, replace the 1 stick with the other stick, and try and boot again.
If you have a successful boot, what ever is left could have a fault...
Basically add 1 component at a time and see what fails (if anything)
I looked for a 4 1 6 beep code but fond nothing, but I think with Asus the first 4 are a Warning code so maybe look at the beep code being 1-6...
Can you record the sound of the beep codes using your phone ? and uploaded them somewhere ?
Trial and Error is probably the best bet in finding the fault....
