help please
11 May 2014
I have a watercooled graphics card 2 of the fan blades have snaped can i unplug the fan from the graphics card and still use it because when it is pluged in it vibrates the pc and make's it loud and noise
Thanks adam
If you want to add pictures, upload them to an image hosting website and use the IMG tags to post them.
It sounds like you've damaged the fans and if they are un-usable, they will need yto be removed. You may need to replace the fans or cooler depending on the damage. 3rd party cooling options are available!
