- 23 Nov 2009
Hello!
I've been out of the loop for way too long. My friend is looking to upgrade his PC so have deicded to sell him my stuff so I need to replace it.
I'll be getting a 5930k (one of the overclocked bundles from here) so that's easily sorted but I've no idea what graphics card to go for.
Currently I own 2 x 290's but want to move to a single card setup (may add another in the future if Crossfire/SLI is worthwhile or if you guys recommend it) but after reading everything I have no idea what card to go for.
I know a new bunch are due for release in the next few months but will need to purchase before then. I don't mind going either nvidia or AMD, just need guidance.
Budget is, in principle up to a Titan X but if better combinations are done for cheaper, I'll gladly take that.
Currently running a Superflower Platinum 1000w PSU so power should be no issue.
Hope this is enough info!
Cheers!
-LiveWireUK
Cheers!
-LiveWireUK
