Do you mean a Ryzen 5600?5060
Not much, the only CPU I'd consider worth upgrading to (for gaming) is the 5700X3D.Will ryzen 7 benefit him? And if so which one?? His game is fortnite and I'm fried
x3d is better for gaming. The cache helps with higher 1% frames and overall game performance compared to conventional CPUs.Thanks guys. May I ask why? I need something to tell him why it's the best. In lamens terms
Thank youx3d is better for gaming. The cache helps with higher 1% frames and overall game performance compared to conventional CPUs.
Is that ryzen 7 5800x3d?5700x3d or 5800x3d. You'd need to replace the motherboard for Ryzen 7000 series otherwise.
Yes, that's the one.Is that ryzen 7 5800x3d?
Great thank youYes, that's the one.
You may want to look at a review or two to get the proper context, e.g.Thanks guys. May I ask why? I need something to tell him why it's the best. In lamens terms
What motherboard has the PC got?Thank you so much..I'll have a look now.
Oh I don't know. How would I find out please?What motherboard has the PC got?
It may need a bios update to support the new CPU.
Oh. Well that's thrown a spanner in the Works lol..thank youEither it will be written on the motherboard itself, you can check in the bios or use a program like cpuz or hwinfo.
In Fortnite, changing the CPU will not be a great upgrade unless you are at low resolution and/or your monitor is capable of displaying high frame rates.
For more taxing games the GPU will bottleneck. Personally, I would save the cash for a bigger refresh later.
I thought that was just the 5800X3D?A word of warning though, AMD has discontinued the AM4 3d
