help pleeeese
10 Sep 2006
chester
ive got wireless broadband and i had it working on my msi neo f motherboard since ive put in the asus striker extreme it connects to the internet the disconnects and then connects and keeps doing this about 50 times untill it says it carnt connect broadband works on my sisters laptop, but i carnt get it to work on mine ive entered the ip addres the default gateway and stuff like that the drivers are installed please help im so confused. :D
On the router do you have mac filtering set up if you do then turn this off and try again. Does your new MB have wireless built into it or is the wireless adapter a PCI or USB device ? if so is it the same one you were using with the old MB.
What is the make of the router ?
