help plez
3 Jul 2007
Rochdale/whitworth
can any one tell me if the OcUK Value Aplus Twin Engine Gaming Case - Silver has a pawer pack and the wattage thanx
It doesn't come with a PSU, and -see to be honest mate- the PSUs that come "free" with cases tend to be very low quality -regardless of wattage-. There's every chance that a low quality PSU will go up in smoke one day, taking most of your components with it. Go for a decent, branded PSU from the likes of Tagan, Enermax, Corsair, Antec, etc.
I'm also not too sure about the case. If you're in that price range, there's no real substitute for a nice Lian-Li PC7. Those 25cm fans on the value case are just silly and tacky.
nice but a bit pricey iv got 350pounds 2 get a cpu mainboard ram gfx and pawerpack and case
sorry lookin at the wrong case i was lookin at the Lian-Li PC-767
the Lian-Li PC-7 isn that nice lookin tho
Neither is the Twin Engine Gaming Case! ;)
You really need to see the PC7 "in the flesh" in order to appreciate the quality. Some might think that it looks "plain", but ithe actual quality of the construction is awesome.
"Value" cases are the exact opposite. They look worse in the flesh than they do in the promotional pictures (poor build quality, jaggy internal construction, etc)
heh "wattage" love it :D should be used more often in everyday conversation :p £350 is not a lot so i'd get the cheapest case you can with a "free" PSU as the remaining budget won't allow for power guzzling componants nehow
*** do u think of the Antec Nine Hundred Ultimate Gaming Case
and at the min iv got a xp3000+ a gig of 266mhz
ddr ram and a x700 so for im thinkin of getin
GeIL 2GB (2x1GB) PC6400C5 800MHz
OcUK Huntkey 500W PSU
Sapphire ATI Radeon X1950 Pro 512MB GDDR3 HDTV/Dual DVI
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
and i can get 125 pound for my old bits 2 get a case and pawer pack
wow fond 1 *** do u think off the Antec Sonata III Piano Black Quiet Case - EarthWatts 500W PSU ?????
It does look pretty sweet actually, I can't really comment on the psu as i've never heard on EarthWatts tbh (does that say it all?) lol
hai 2 u m8 mbe if u stppd pstin in txtual it *** hert mai i's les?
if u wantz a gd case nd 'pawerpack' (spelt power supply by the way) den u shuld b lokin @ da antec cases dey iz da bom
jeez, most of thats going to be stars, so to translate:
hey, don't write in text, it's bloody annoying.
if you would like a good case which includes a power supply, may i suggest the antec range, they are, in general top quality cases, some of which come with power supplies, try for instance the antec sonata II (which looks far better than the sonata 3 :eek: )
:p :D :cool:
