Help Plz with my New Monitor
5 Sep 2012
Edinburgh
Hi Folks I have just bought an Asus PA248Q 24" Monitor :D
This Monitor has 4 USB 3.0 Ports but i am not sure that they are working ? :confused:
Do I need a special Cable or something to connect my Monitor directly to my PC ?
It says this (to use the USB 3.0 port plug the smaller end type B of the USB upstream cable to the monitors's USB upstream port and the larger end type A to your computer's USB port )
As you can guess i am not to Technally minded :rolleyes:
Any help would be great folks
Cheers Lee
