help plz
2 Oct 2005
Glasgow
If this is the wrong section can a mod plz move it
I have a 360 and my isp is N^L
i have my 360 connected with the ethernet cable 2 my cable moden and my pc connected
via usb ( its the blue modem new 1 )
but the trouble is 2 connect 2 xbox live i have 2 turn my pc off and reboot my modem and vice versa for my pc
iam running xp home with 4 meg n^l
any1 have any ideas
sry this is doning my nut in big time
plz some1 help
I connect to the internet using a usb modem. All you need to do use ICS to share your connection, the connect to XBL as normal. Always works for me.
As above really. If you would like more clarification, everything you need to know about the various methods of connecting to Xbox Live is in the manual and also on the website.
