help plz ....
16 Dec 2010
:confused:started my pc up today and my main monitor came on and is a strong purple . my 2nd monitor is ok. when i swap plugs on back of gpu main monitor is ok an 2nd lcd tv dont come on ?????:confused:
You may have a dodgey output on the gpu. can you check it on anyone elses puter? What connections you using? Can you use a different output?
