Help plz
20 Mar 2011
i have the dell u2311h and have been using it fine with my pc however i since bought a hdmi to display port cable so i could use my xbox on it, but i am now getting no signal on the display port but the dvi works fine?
Hi there,
You say you got a HDMI to Display port cable? (not to be confused with a Displayport to HDMI adapter)
Is that an active cable and what make and model number is it?
Ah, in that case it won't work. HDMI and Display port are entirely different digital video signals. The passive cables only work if you're using them with a graphics card that has the ability to output a DVI/HDMI video signal along a passive adapter. Your xbox can't do this.
Personally I would suggest hooking it up using an adapter like this, and use a HDMI switch box like this if you don't want to be forever swapping over the cables.
