Help Plz
25 Oct 2013
A very annoying problem has started cropping up that I cant seem to fix - help/ideas appreciated.
For the last month or so when I go to You Tube after a while my pc will suddenly lose the sound on the video and then a few seconds later I will just get the "round circle thingy" in the middle of the screen and eventually a "your Tube has encountered a problem - try reloading" message.
it wont resolve itself unless I reboot.
Couple of other clues - if I then visit any website with n embedded video after the YT crash - they dont work either.
If I do some general browsing before going to YT - I will get the problem immediately. I have partially solved this by always going to YT first but that only lasts for a while before it eventually hangs.
Doesnt matter what browser I use
Win 10 Version 87.0.664.75 (Official build) (64-bit)
I know its probably a needle in a haystack but any ideas ?
thanks
