- 1 Oct 2006
- Suffolk
I have bought a GA-H170TN mobo cheap and getting some bits new and old together to get a cheap build done. Only problem I have is I notice this motherboard is not powered like normal ATX boards with 24 pin connector from a PSU. It has the option to use a DC external power supply or a PSU which connects via a 2 pin power connector on the board. Now I have ordered a Cool Master Lite PSU and looking at other PSU's I have lying about I do not see any with a 19v 2 pin connector. Do I need some sort of specialist connector to use a regular PSU to power this?
I opted for a PSU over a external supply so I can power hdd's and such. Plus have a spare PSU for in a time of need.
Here is a description and specs of said power input: DC Input: The GA-H170TN can be powered with a *regulated 19V DC external power supply though the DC jack on the back panel board or internally via the 1x2 Mini-Fit JR power connector (Molex 5566-2). Not suitable for use connected directly to a battery.*
