- 25 Mar 2004
- Fareham
Hi all,
Have a bit of an odd one but it's driving me crazy, I need to convert a hex character to the correct text value, for example in PowerShell you can do this:
$Hex = 0xc3a1
$Text = [Convert]::ToChar($Hex) ; $Text
This returns the string value 'A' correctly. The problems occur if I want to use another character such as á (see http://www.fileformat.info/info/unicode/char/e1/index.htm).
á uses the UTF-8 (hex) value:
0xC3 0xA1 (c3a1)
What I need to get my code working is this instead:
UTF-16 (hex)
0x00E1 (00e1)
If I run my code against 0xc3a1 instead it returns '?' because it converts it to a ? character. $Hex = 0xc3a1 Returns value 50081 which is incorrect.
Any ideas how I can convert the hex value c3a1 into the correct value e1 / 225 instead of how this is currently being calculated?
Cookie to the first one to solve this!
Powershell can use the general .net framework parameters for conversion, I am sure I am just missing something obvious here!
Thanks!
$Hex = 0xc3a1
0xC3 0xA1 (c3a1)
UTF-16 (hex)
0x00E1 (00e1)
Thanks!
