Right ok my friend told me his computer 'Wasnt Working' so i just assumed there was a virus or needed a reinstall so i offered to help.
I get his computer to my house and when i pluged it in it just turned on automatically for 5 seconds then turned off then repeated the process over and over. At first i thought it might be the power switch being faulty so i unplugged that and it did the same thing.
So i changed PSU thinking that it might be a dodgy connection, but that didnt work.
So i asked you guys on here and was told to put a new mobo in it, so i did that ordred the below.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-114-MS&groupid=701&catid=5&subcat=326
Got it home and rigged it all up and plugged the power back in, good news the computer didnt turn on, on its own anymore. So i pressed the power button and it whirred up but wouldnt display anything on screen just a no signal message on my monitor so i did the following:
But couldnt get a screen to apear it is driving me mental but i know it is fixable! Could it be the analog cable i am using? or the ananlog port on my Monitor?
Thanks guys apreciate any help.
- Removed graphics card and ran with onboard graphics
- Tried all 3 bits of ram in each of the two slots
- Unplugged HDD
- Unplugged all USB connectors etc
- Removed all PCI cards
- Cleared Cmos
