HELP! q6600 only showing 2 cores?
10 Oct 2007
kidderminster
HI, ive just upgraded from an e6600 to a q6600, installatiom went well i also reset my bios and made sure all cores were enabled but using the features below i dont think the other to cores are being seen. also coretemp still thinks theres an e6600 in there. Any idea folks?:confused:
Yes the bios show q6600 4x cores, didnt really want to do a reinstall, ive got to much stuff i need on the drive
Backup what you need to keep. Windows is sometimes funny when changing hardware
You could try using the windows repair function on the dvd.
Did you clear the CMOS back to default BIOS settings before you swapped the CPUs it may be the problem i don't think windows is the problem because it shows C2Q in system rating
Sorry, been to tescos.
Ive tryed all of the above bar a windows reinstall.
Strange that coretemp still sees it as en e6600
