Hi guys,
got a problem, Computer worked fine for approx 2 months then it started to shutdown a random times, could be playing bf2, surfing the net, just sitting there doing nothing or even just after post when windows is loading. It will just switch itself off, no bsod or nothing. Reinstalled windows 2 weeks ago and all was well till this morning and its started to do it again. Once when it was loading windows and once when it was in windows but doing nothing.
Specs are
4400+ on a DfI lanparty mobo with 2 gig corsair ram.
Temps are low 30's idle and mid - high 40's under load.
I have noticed that in sisoft sandra 1 core seems to get 1.35 volts but the other only gets 1.15volts, even under load.
update, cpuz shows both cores at 1.34v
Any ideas guys.
Thanks
Babyface UK
Specs are
Any ideas guys.
Thanks
Babyface UK
