Permabanned
- 21 Jun 2007
- SPAM
Where to start.
Browsing the forum last night, pop up apears *new updates* for windows (vista32)
I click update > Prompted to restart > restarted.
Boot goes fine ? get that vista globe just before the desktop would apear
Screen goes black > then monitor switched off
Safe mode I get a screen and get access this forum.
I have tried system restore to remove the latest update > didn't work
Checked the device manager > no conflicts > no missing drivers
What I think it might be > well I downloaded and installed those leaked patches that were floating about.
When I try and access windows update the computer brings up the im thinking cursor then does nothing > should I try a restore further back > maybe uninstall the graphic drivers? > Anything else I could try?
SPEC
Its a hell.
GFX is a 8600
AMD
I think thats all you need to know as it is a HELL after all.
can someone please help?
SPEC
Its a hell.
GFX is a 8600
AMD
