Help Recent Build Keeps Restarting with Wifi Issue
9 May 2010
I've recently built a new system and its starting play up with odd results.
Basically it restarts but when it does, the Wifi and ethernet stop working.
The board is a Gigabyte Aurus Pro AX with built in Wifi.
Everything else seems to work fine but I just have no internet connection.
The Wifi is on and detects available networks and connects to them but it says no internet available on them.
I've also tried using my phone as a hotspot and also tried using a USB Wifi dongle with still no internet connection in both cases.
The only way to sort it is to reset the PC which solves the problem but is a pain to have to go through.
It's now happened 3 or 4 times in 2 months, is there any way of getting to the bottom of this?
Which chipset is the board?
"Basically it restarts" - I'm confused, do you mean the computer resets itself and returns to the BIOS & logon screen?
Its a B550 board.
Restarts as in the PC switches off and then back on again, everything looks normal other than the wifi and ethernet not functioning.
