Hey all,
I recently posted my build and you can see the old build from my previous post:
I decided I didn’t like how one of the runs from the CPU block out because the diameter had almost halved in its bend.
I’ve now reconfigured as seen below. At the top right the config is Alphacool 90° to 90° to allow for a nicer run and you can see I’ve moved some runs around.
My issue now is that it won’t fill. It gets to halfway on the first run (at the front) and that’s it. It’s almost as though the pump is on low rpm?
Pump/res is Corsair xd5
Before reconfig I had noticed some air bubbles that were persistent, but no change in temps so I assumed pump was OK.
Things I’ve tried:
-Different 24 pin jumpers
-Different molex connectors
-Changed extension cables
-Looked at all runs, they appear to be kink free
Our last thought is to quickly load in to bios, to check RPMs but I’m fairly concerned about that idea.
Is it possible that it’s stuck on a hardware RPM?
Appreciate any help, thanks Matt
Thanks all for advice. Went for XD5 in the end - think it’s a really neat res with plenty of opportunity to change my runs around. Would anyone run their tubing differently here? I’m wondering how I can minimise curves.
I’d like to go to inlet at top of res from 360 rad but the soft tubing just does not like to go that way... Would a 45° fitting help here?
Bottom left res -> GPU -> 240 top rad -> CPU -> 360 front rad -> res
Things I’ve tried:
