Hi guys, just received the Powercolor ATI Radeon HD 4870 PCS Extreme GFX card, popped it into my system, first go stuff seemed to work, booted into windows (didn't change anything whilst I was there, had 2 monitors plugged in and only one was working).
I then restarted and it now it no longer works at all! Depending on how many times I start / restart the computer, sometimes the GFX fan stays off and sometimes it whizzes full blast, but my PC now wont post / boot (nothing displayed on screen at all with DVI cable in either GFX socket).
I have a maximus formula as my mobo, the LCD display just gets stuck on VGA Bios but gets through CPU / Ram etc. fine.
I swapped the card back to a very old x850xt and everything was fine, booted into windows, updated my mobo bios, etc, swapped back to the 4870 and still nothing!
I've tried resetting cmos, updating the bios, powering on / off numerous times, reseating the card, using various power cables to power it (combination of adapters / normal 6 pin PCI-E connectors) but no joy.
I can't for the life of me figure out what's wrong + what to try next and was hoping one of you lot could point me in the right direction.
Thanks
Thanks
