Help regarding Phanteks 600s.
25 Nov 2015
I have everything ready for my new build minus a case. I have a NH-D15 along with Team Group 8 Pack ram. Just wondering if anyone knows if the 600s is big enough with the front fan raised to fit in the ram.
Thanks in advance.
The max CPU Cooler clearance is 190mm so plenty of space.
If you have the normal TG RAM, you could remove the top section of the heat spreader to make them only 37mm high.
