- 19 Aug 2014
A few years ago now; I had a PC built by overclockers.
I want to replace the case. the current case is a Zalman H1; with a H105 CPU water Cooler bolted onto the underside of top of the case. I want a replacement high quality case - ideally that is a MIDI form factor that can take my current GTX 780 Direct CU II; but soon to be a GTX 1080.
Can you recommend a good quality case that will take these components easily?
many thanks for your advice and help.
