Help replacing Ek Phoenix Rad
25 Jan 2008
Help !
Managed to punch a hole in my Ek Phoenix 360 Rad. I still have the Phoenix Cpu and Gpu block that connect via ek qdc quick connects. ( 2700x and Vega 64)
Have tried glue and putty but still leaking.
Rad / pump combo
https://www.overclockers.co.uk/ek-w...nix-360mm-radiator-core-module-hs-006-ek.html
Cpu block
https://www.overclockers.co.uk/ek-water-blocks-ek-mlc-phoenix-intel-am4-cpu-module-hs-008-ek.html
Similar gpu block
https://www.overclockers.co.uk/ek-w...80-ti-gpu-module-acetal-nickel-wc-9l1-ek.html
The rads are no longer sold and I'd rather replace with a standalone pump/res and 360mm rad and connect to the phoenix cpu and gpu.
The Phoenix is 16/10 tubing and I'll take the qdcs off the damaged rad side and use on the new tubing.
So could anyone recommend a suitable rad / pump res combo and tubing / fittings. I'll go for clear soft tubing for ease and eventually I'll replace the dark ek tubing on the gpu / cpu blocks, but for now I'll connect the new stuff into the old via the ek qdc connects..
Very lacking in water cooling knowledge and need to replace quickly. Any help appreciated.
Used the configurater, does this look ok ?
My basket at Overclockers UK:
  • 1 x Online Water Cooling Configurator - ONLINE ONLY = £287.30
    • CPU Block:Unwanted
    • Single Radiator:Unwanted
    • Triple Radiator:EK Water Blocks EK-CoolStream PE Classic 360 (Triple Fan) Radiator
    • Reservoir:Unwanted
    • Pump:Unwanted
    • Dual Radiator:Unwanted
    • Compression Fittings:10xEK Water Blocks EK-Torque STC 12/16mm Soft Tubing Compression Fitting - Black Nickel
    • Quad Radiator :Unwanted
    • Fluid:EK Water Blocks EK-CryoFuel Blood Red 1L Premix Watercooling Fluid - 1 Litre
    • Fans:Unwanted
    • Tubing:2xMayhems Ultra Clear Watercooling Tubing (3/8 - 5/8) 16/10mm - 1m
    • Pump/Reservoir:EK Water Blocks EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
    • Hard Line Fittings:Unwanted
    • Acrylic Tubing:Unwanted
Total: £297.20 (includes shipping: £9.90)​
Help !
Rad / pump combo
Cpu block
Similar gpu block
Use quik steel and poke it around with a tooth pick. If your using superglue you want a blob over the hole and some bicarbonate to give it strength
Cheers, i did use some Rapid Metal , but i didn't poke it through enough and thats where I went wrong, I bet the toothpick method would have sealed it.
I've tried a few times since and covered a massive patch around it, but still weeping a tiny amount.
I've since ordered the bits to change to an open loop. In the end an Alphacool Nexxxos ST45 360 Rad, EK-XRES 140 Revo D5 pump etc, mayhems tubing and coolant. Didn't order enough fittings for a drain point, so waiting a few more bits to arrive tomorrow and will swap out.
No problem, you live and learn.
Didt order enough bits I done that too a number of times lol
Mostly sorted.. still no drain point as managed to order the wrong parts !.
Pump not quite mounted right as thought there'd be a bracket of some sort to mount from underneath.
Tubing a bit too long in places and need to tidy up cables in the morning. Will sort out tubing when flow meter and drain parts arrive.
