The wiper motor on my car has burnt out (quite literally, it stinks and I want to remove it whilst I wait for a replacement).
I'm struggling to remove it. There are three bolts (pictured below) holding it in place. They have an odd pattern I've not seen before and can't find on the net. I've got me hand behind the panel where they're attached and they seem secured by a butterfly nut but with 3 wings rather than 2. It also seems closed - the end of the nut is smooth and has no hole/bolt sticking out. Either way, holding it in place with a clamp and trying to remove the other with pliars isn't working and I think I've nearly ruined one bolt trying. I've already gouged that one out with a torx trying to get it to bed in and turn.
Anyway, any help much appreciated as I'm getting frustrated and daylight is running out. I would like to remove it before work tomorrow as I take people out in my car.
The 'bolt'. The plastic which the motor assembly sits on sat between two rubber rings between the body and bolt. It looks like it could slide off but the three anchoring points are opposing so this would be impossible as it is.
The nut behind. Got my phone in there for a pic.
Here's the whole assembly.
