- 18 Dec 2006
Hi all!
Earlier today I decided to update my Catalyst drivers to the latest 7.1 set.
Normally when I have updated my ATi stuff I just install it over the old drivers without any problems (probably the first mistake right there).
This time however, when the program tried to install the control center I was graced with a BSOD and a reboot.
I then decided to try and uninstall all Ati stuff using add/remove programs, but again, when trying to uninstall CCC - BSOD.
So I thought sod it, I don't really use CCC anyway, and the driver itself seems fine. BUT whenever I right click on the desktop it automatically tries to install CCC and crashes my computer if I am not on the ball and click cancel. Very very annoying.
The following list is what I have tried so far to fix this problem:
System restore
Manually remove all Ati directories, including those in doc + settings
Manually remove all ati*.* files from system32 and system32/drivers
Delete all ati references from the registry.
Use registry mechanic and regcleaner to try and fix the registry.
All of the above in safe mode.
I have looked at various tweak guides etc but still no joy.
Any ideas guys and gals? Am I being daft and missing something obvious?
The ideal solution would be to get rid of all Ati bits and pieces and just do a fresh install, but that is easier said than done.
Thanks for reading, any advice would be greatly appreciated.
System restore
