Hi guys, I posted earlier regarding my laptop issues with it no being able to boot and so on. Sadly, I got no replies... but the laptop has completely failed now (It posts but doesn't boot)... and the HP diagnostics suggest that the Harddrive is to blame.
Now I did some research and a replacement HP approved what not drive is around £80 :|... for a 250 gb drive. Now its a standard Laptop Drive with Sata connection.
I was thinking that I could maybe put just a another laptop drive in (I would then lose the laptops recovery partition and what not) and then install Win 7 on it.
A few questions... its running HP's bios... Will it flag any errors? Else, do I need to flash it (I really really really really REALLY don't want to do this)...
What else do I need to look out for?
and in your opinions, what do you think my next course of action is? I'v already lost 100 GB's worth of data (I can get the important stuff back though
) and I really don't want this happening again so all advice is welcome.
Laptop is a HP DV6-1111ea with a AMD Turion x2 Dual Core Mobile RM-72 running at 2.1 Ghz with 4 GB of Ram. Graphics card is unknown (I forgot) but I think its a Ati 3 series card... with 256 dedicated but it has access to the rest of the mem.
Thanks in advance
Ash
) and I really don't want this happening again so all advice is welcome. Laptop is a HP DV6-1111ea with a AMD Turion x2 Dual Core Mobile RM-72 running at 2.1 Ghz with 4 GB of Ram. Graphics card is unknown (I forgot) but I think its a Ati 3 series card... with 256 dedicated but it has access to the rest of the mem.
Thanks in advance
Ash
