- 6 Jan 2013
- Rollergirl
I'm installing an EK FC680 GTX+ onto a gigabyte gtx670. I've removed the heat sink and fans, but there is a separate heat sink that isn't attached by screws. How do I remove it (it's on the right above the R22 components).
Sorry about the image size...
