Help required
29 Jan 2014
Hi all I've just started my first Intel build and I'm having problems , I've put it all together it turns on power supply spins for a few seconds then stops everything comes on for a few seconds off then on then off then on what could it be
Both PSU plugs in the motherboard? The big one and the 4 or 8 pin?
RAM insterted correctly?
Give it a try with Just 1 stick of RAM and the CPU using onboard graphics and not GPU.
Full specs would help if you can!
Think it's the 8 pin connector I haven't connected but I can find the cable for it I got the evga 850 gold modular I have the two cables the go in to the big connector in but no supply for the 8 pin
Daft question - are they handed so you can't plug the PSU end in the motherboard?
Is it possible to take some pics :)
Got it sorted now , one of the locators in side wasn't straight so changed it out and it's on
They can be tricky on the odd occasion, least you sorted it :D
IIRC the end that can "split" into 4/6/8 plugs is the board end, the one that is a single unit is for the PSU
Thoutght I double check as sometimes images on the websites aren't always up to date :p
