Hi guys,
Think this might be terminal but thought i'd ask those in the know.
I have an HTC One M7 that has somehow become corrupted, it asks for a decryption key when started up and upon entering it it says:
"Decryption unsuccessful, the password you entered is correct but unfortunately your data is corrupt".
Booting into recovery gives the following:
Factory reset does nothing, the phone is not rooted, has standard recovery and does not have USB debugging enabled (and obviously can't enable it as I can't boot into the OS).
I've had a good read, but practically everything requires USB debugging to use ADB/fastboot etc.
Just want to reset the phone to standard - would be grateful for any help.
Thanks in advance.
Thanks in advance.
