Help Restarts
24 Aug 2006
Was playing COD4 and got screen lockup, had to restart
Then windows reboots with high pitched whine and freezes
I took overclock off and restarted, everything ok, bam restart
any ideas?
my temps seem normal when I check. overclock has been fine for over 1 year at 2.8ghz. anyway, i managed to tyoe this before it freezes.
creative lap driver issues? try disabling the audigy and run the onboard for a while and see how you get on.
Is your cpu and ram prime stable?
yes its stable
its not even a big overclock 50c-60c under load
i had a problem with an audigy 2 once, where if it was placed on *** bottom pci slot it was cause restarts
audigy is your prime suspect then, maybe uninstall drivers and download the latest from creative
never had a problem with my Audigy 4, but it did bsod once when installing the drivers. buggy as hell!
