Hi all,
Been playin with rivatuner to create fan profiles with my new 8800gt, but in the hardware monitor it detects my Fan duty cycle (fan speed) as 100% all the time!?!?!
The Card is a Gigabyte 8800GT the one with the Zalman cooling soloution on it.
The card temps at idle are about 39/40c and the fan noise doesnt seem to loud so not sure if its running at 100% or not!?!?
On the card there are two 2 pin slots for a fan.......this is the second card i have had due to the first been fauilty, the other one had a different zalman fan on it and that was plugged in to the other slot. Would this cause it to read fan speed as 100%
Is there something else i can use to monitor fan speed or is there a problem?
Thanks in advance for any help/advice
Mark
Mark
