Help! - RX480 both fans have stopped workingq
25 Feb 2012
Help! both the fans have stopped working on my Nitro RX480+ OC.
GPUZ still saying there at 15% but there obviously not. I also tested with and trixx fans check and thats telling me I should contact the retailer/manufacturer.
Classic -First day of my holidays no gpu :(
If i drive down to overclockers - do you think I can get it sorted or a replaced that day?
I've got the same card, the fans don't turn on until about 52C.
When I was playing around with Trixx once it locked my fans to 0% until I restarted. That's how I found out thermal throttling works very well, XD.
All few cards do not spli fans until they hit 50-55. Same applies to NV cards like GTX1080, 1070, 1060 etc
As the other say, run something if the temp goes above 60c and the fans haven't started there is a problem.
Or run afterburner and manually set the fans to run and see if they start.
