Help selecting a gaming rig!
12 Aug 2011
Hey all. I'm sure these threads must get annoying, but I do need some help.
Basically, I'm looking to get a new gaming rig. I want to be able to have this built by Overclockers, as I am not comfortable doing so myself. I want to spend about £800, £900 max if possible, though I >can< push that a bit of need be. No monitor or such needed, just the tower.
My problem is, theres a few ways to meet that kind of range on Overclockers. Do I get a cheaper base system and select some of the upgrades? Do I go for one of the higher range systems and leave it as be?
Should I stick with i5, or is getting i7 important?
So, if anyone can help, it'd be appreciated. :)
What would you like the PC for -- if you're into games then more will be spent on the gfx card, if you just need an office pc then you may be able to spend less and if you need a renderer/CAD PC then a multi-core CPU such as I7 or hexcore is more appropriate.
At the moment the sweet spot is normally a p67/z68 board, i2500k cpu, 6850 gfx card for all round performance.
Jennidc: This is very much a gaming rig. But as I'm not building this myself (do not have nearly the confidence to!), I'm looking at the gaming range overclockers offers.
Stone22uk: I have a copy of Windows 7 I can install myself, but I do not know the process of installing a OS onto a blank pc. Is it simply insert disk and go through the usual process?
If you have the OS disc, you just need to insert the disc then boot the PC and it should fire up into the windows 7 installer, and then its a case of following the on screen instructions.
Just to make sure it is a 64 bit version of Windows 7 you have?
Yep, 64 bit. So thats a bit off the cost, good. :)
And silly me, I just realised that you can order the components you want and Overclockers will assemble them...
But yes. £800 preferable budget, £900 pushing it... Do not need OS, monitor, keyboard or mouse. Gaming rig. I'm guessing that i7 processor isn't essential going by what you get out of it for its value.
Ok - something like the below the PSU is up to SLI'd 570's for the future -
Gainward GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £239.99
(£199.99) £239.99
(£199.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
(£141.66) £169.99
(£141.66)
Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £146.99
(£122.49) £146.99
(£122.49)
OCZ Z-Series 850W '80 Plus Gold' Power Supply £99.98
(£83.32) £99.98
(£83.32)
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £47.99
(£39.99) £47.99
(£39.99)
Zalman Z9 Plus Tower Case with Fan Controller - Black £44.99
(£37.49) £44.99
(£37.49)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98
(£33.32) £39.98
(£33.32)
DeepCool Ice Edge 400-FS Ultra Quiet CPU Cooler (Socket LGA1366/1155/1156/775 and AMD AM3/AM2+/AM2/K8) £24.98
(£20.82) £24.98
(£20.82)
Samsung SH-S222AL/RSMS 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail £18.98
(£15.82) £18.98
(£15.82)
Sub Total : £694.90
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 20.00% VAT : £141.48
Total : £848.88
Your basketProduct Name Qty Price Line Total
PNY Geforce GTX 580 1536MB GDDR5 DVI HDMI PCI-E Graphics Card - (GMGTX58N2H15ZPB) £335.99
(£279.99) £335.99
(£279.99)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £155.99
(£129.99) £155.99
(£129.99)
Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** £70.98
(£59.15) £70.98
(£59.15)
OCZ ZS Series 650W '80 Plus Bronze' Power Supply £62.99
(£52.49) £62.99
(£52.49)
Silverstone Precision PS03B Midi Tower Case - Black £41.99
(£34.99) £41.99
(£34.99)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST3500413AS) £30.98
(£25.82) £30.98
(£25.82)
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
(£19.99) £23.99
(£19.99)
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) £23.99
(£19.99) £23.99
(£19.99)
LiteOn IHAS124-19 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
(£14.16) £16.99
(£14.16)
Antec Tri-Cool 3-Speed 120mm Fan - Black £2.99
(£2.49) £2.99
(£2.49)
Sub Total : £639.06
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £19.10
VAT is being charged at 20.00% VAT : £131.63
Total : £789.79
Cheers for those. Though I'm not seeing the Zalman Z9 Plus Tower Case with Fan Controller in the "Build your system" listings, unless its under one I'm not clicking.
So you want one thats all "done" for you?
If so, then that changes everything, the above specs you will need to assemble yourself.
This - http://www.overclockers.co.uk/showproduct.php?prodid=FS-176-OE&groupid=43&catid=2040&subcat=
With a GTX570 upgrade.
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System £600.00
(£500.00) £600.00
(£500.00)
Options applied to the above product:
Overclock selected £20.00
(£16.67) £20.00
(£16.67)
No Operating System £0.00
(£0.00) £0.00
(£0.00)
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) £35.99
(£29.99) £35.99
(£29.99)
OcUK GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £249.98
(£208.32) £249.98
(£208.32)
No Hard Drive Upgrade £0.00
(£0.00) £0.00
(£0.00)
Sub Total : £754.98
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £15.50
VAT is being charged at 20.00% VAT : £154.10
Total : £924.58
Or the Intel 10200i Configurator
Intel 10200i Configurator - Extreme Gaming System £898.90
(£749.08) £898.90
(£749.08)
- No Webcam Option (Zero Cost)
- No Headset Option (Zero Cost)
- Speakers Not Selected
- Monitor Not Selected
- Mouse Not Selected
- Keyboard Not Selected
- Full Cable Management
- Networking Not Selected
- No Operating System
- Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK)
- Onboard Sound Card (ZERO COST)
- OcUK 22x DVD±RW SATA ReWriter (Black) - OEM
- No RAID Option (ZERO Cost)
- No Second Hard Drive Option (ZERO Cost)
- Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX)
- No Graphics Card Upgrade
- OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 PC Game
- Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
- Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard
- Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3)
- Stage 2: Overclock of CPU - 15% Overclock (Proceesor speed x1.15)
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
- Antec 300 Three Hundred Ultimate Gaming Case - Black
Sub Total : £749.08
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £13.00
VAT is being charged at 20.00% VAT : £152.42
Total : £914.50
Thanks Stulid, that second one looks good. Though it does make it horribly tempting to push budget a bit more for a bigger harddrive..
