- 11 Aug 2003
- Taunton, Somerset
Under XP do both graphics cards need a monitor attaching to the card?
I have set as per Stanford's instructions, although I don't have a second monitor as I have read somewhere this is for vista setup - correct me if I am wrong
The first client starts no problem the second gives the following error message
"At present your GPU in not supported or you need a current driver. You may wish to consider running our standard client, which you can download and folding.stanford.edu."
I have the same diver for both cards (6.14.11.8120) and I have setup the shortcuts as they suggest in the guide targets for the shortcut are the same but one has -gpu 0 after it the has -gpu 1 after it and they both start in their own respective folders in the applications data (Folding@home-gpu and Folding@home-gpu2)
I can not start the second client regardless of the first client being started or not
Any Ideas why I can start the second client
*edit* mobo is ASUS P5N-E SLI. Cards are not linked with and sli connector
