- 23 Aug 2007
- Rothesay
As title suggest's im looking for help setting up a second gpu client
ive just installed a second 8800 GTS 320 card into my system and set system
up so i can enable/disable sli
Ive had a quick read of the guide on stanfords site but still a bit lost.
from what ive read i need to run seperate client naming it gpu1 and run current client as gpu0
the bit i dont understand is it say's i need to have an output on the second card but dont have room for second monitor is there a way i can do this without resorting to the dvi-vga adapter bodge.
