Help setting up home network - if feasible.
21 Jun 2006
UK
We have no fibre in my area as yet, so we're limited to ADSL at around 5mb.
I have however managed to connect with a 4g router giving me speeds of around 100MB which is sufficient.
The 4g router (Huawei B525) is in the loft (Wifi A).
Wifi A is hidden and is only used to manage the 4g router.
Downstairs I have an Asus RT-AC86U which is the main hub for the house - Wifi (B).
I have the 4g router connected to a GS105E switch in the study via ethernet cable ran in the walls.
My desktop connects via Ethernet to the same GS105E as does the RT-AC86U in the living room.
Herein lies the problem, the traffic from my pc goes via the switch to the 4g router, whereas i would like it to go via the RT-AC86U as the network storage is there.
Is there a way I can configure the GS105E to route my pc's traffic via the AC86U with my current configuration?
I could run another cable as oer the second image, but there is no more room in the conduit from the loft to the living room so it would a PITA.
I don't get what you're hoping to achieve by connecting the Desktop directly to Router besides having a dedicated 1Gb line for the Desktop, are you using some sort of NAS function on the Router or is there a device not on your map?
You could bin the switch and put the Router in the network location the Switch is now and get a Wifi AP and put that in where the Router was downstairs.
There's your problem. Change the GS105E to a router. In fact, just swap it with your RT-AC68U if that has an upstream port and install a WAP downstairs.
All my traffic from my desktop goes directly through the 4g router, I am currently unable to access the RT-86U and the network storage which is connected via it.
Is the ASUS in the same IP range as the 4G router and also have you switched off DHCP on the
ASUS?
Your core issue is that you have 2 Routers on your network.
Because if things are setup probably you won't have to physically change anything.
