- 28 Aug 2003
- N Ireland
adsl based
router is netgear dg834g (already have this)
i need to get at least an 8 port 10/100 switch, have the ability to stick in 3 or 4 network cameras (will a PoE switch work with network cameras??)
and have the ability to run 50m of cat5 cable to another area and have a wireless AP here
will dg834g>switch>50m run cable>netgear602 wireless AP work ok? - with respect to the wireless signal from the adsl router not interfering with the wireless from the AP? (there are two separate areas that require wireless access, but the signal won't reach from the dg834g on its own)
any advice re hardware appreciated
thanks
thanks
