Hey folks,
Having a tinker with pfSense as I'm moving to Sky Fibre so fancied getting a little more control now that I'll be using the connection for more.
I've got a Windows 10 "server" with that I'm using for Plex that's on 24/7 so I fancied that would make a good pfSense box if I ran it in Virtual Box.
The old setup was:
Sky Modem (WiFi disable, DHCP enabled)
switch
Server PCs Unifi APs
The new setup I figured would just be:
Sky Modem (WiFi disabled, DHCP disabled)
Server
- new 2nd NIC connected to modem
- pfSense running in Virtual Box (DHCP enabled on LAN side)
- onboard NIC connected to switch
switch
PCs Unifi APs
So keeping in mind that I still want my host server to function correctly (i.e. connect the the internet and the LAN, through the pfSense VM) and just a little confused about what network addresses need to be static and which ones can be dynamic.
Also, how do you configure you network on your host server to connect through pfSense? Or how do I check... because with DHCP disabled on my Sky modem I've currently got a static IP assignment and gateway setup to point to that, so that's to stop my network traffic just utilising that rather than being forced to use pfSense?
Anyway, a bit of help to point me in the right direction for docs that might cover my specific problems i'll face would likely be a good start, or any other advice much appreciated
EDIT: I should say when setting this up I almost feel like I need a 3rd virtual NIC or something to configure for the HOST machine... I'm just not use if that's actually what i'd need.
The old setup was:
switch
Server
switch
PCs Unifi APs
