Help setting up port forwarding on virgin hub 5
23 Jan 2005
Hi I set up wireguard on my unraid and I have to change this
Remark: configure your router with port forwarding of port *****/UDP to xxx.xxx.x.xx:*****
You don't need to star out the port or your local IP, it's useless to anyone. My Hub 5 is in modem mode so I can't give you a screenshot walk-through. It should be very straightforward and self-explanatory though? Go to the port forwarding section, add a new rule, forward port 51820/udp (or whatever you chose for WireGuard) to the local IP of the machine running WireGuard, on the same port. For example 86.6.2.12 port 51820/udp > 192.168.0.12 port 51820/udp. Don't forget to save/apply.
From memory the sh5 will show a from port and a to port (internal and externl). Just enter 51820 in all 4 boxes and enter the internal ip of your unraid server.
I assume you have used a docker and using the br0 network in docker so it’s on the same subnet as your main home network?
Easy as this.
Advanced settings > Security > Port forwarding
> Create a new rule
Add the settings below changing the internal IP of the device you want the router to forward too
> Click Add rule > done.
