Help setting up router please
20 Feb 2018
Hi all trying to setup a to tp ink c7 ac1750 router. I use virgin as my isp so I put my superhub 3 in modem mode. Connected the router to the lan socket on the super hub. But when I try to go to the router setup page I get a massage saying local management via https is disabled conmect using http. so can't get any further. Could some please tell what this means and how to correct this. Thank you in advance
Whatever the IP address is in the address bar you are trying to get to. Type http:// infront of it instead of the https://
Chances are it is using the same IP range as the SuperHub was and your browser has cached a https:// destination and it is reverting to that.
