help setting up wireless Access Point
5 Nov 2002
Melbourne
Finally fed up of the PS3 crappy wireless so I have my netgear DG834PN currently being used for wired & wireless throughout the house. I dug out my old netgear DG834G which I would like to hook up to the PS3 via the lan port & the 834G pulling the wireless internet from the 834PN.
I have tried mucking about setting it up but keep failing so I turn to you people of OCUK. If it is possible to use 2 DG834's in this way. It took me 3 hours the other night to download a 64mb update on my PS3 :(
cant see why not, you wont be able to use the WAN port on the non gateway router which will mean it is being used as a 4 port switch.
You will also need to turn off dhcp on one of the devices and any other duplicate services that you will conflict with each other.
Internet --- Gateway DG834 ---- DG834 --- PS3
is that what you meant?
