Help! Soundbar mount
  • Thread starter Thread starter Bry
  • Start date Start date
Bry
Bry
24 Jul 2005
Help me overclockers!
I have a 55" LG oled
A Samsung ms750 soundbar
I have wall mounted the tv and purchased the following to mount the sound bar to the tv
https://www.vogels.com/en-gb/c/sound-3450-sound-bar-mount
The tv wall mount is movable so I cant just fix the soundbar to the wall it needs to move with tv.
Only problem is the speakers are facing downwards ! !
Didn't realise until it was all put together as the mounting holes on the soundbar are on the bottom and not the back.
Looking at other sound bar mounts they only seem to attach via the back too.
Is there anyway I can mount my soundbar to the tv and have the speakers facing towards me as designed?
(Preferably using my existing soundbar mount....
Type this into e bay as I think this is what you need (on my phone )
Universal Soundbar Speaker Bracket Mount Holder Below Above Sound Bar Television
Use some L brackets?
Not sure which ones to buy. The samsung speaker comes with l shaped brackets but the screws are far too big to fit the mount.
Thanks, just had a look but all the results seem to show mounts to attach to the back if a soundbar whereas samsung soundbars have the mounting hole on the bottom and not the back. Same as my existing mount. Unless I'm missing something.
