Help spec me a build with no GPU under £1000
30 Mar 2012
Hi guys,
Looking for help to spec me a build under £1000, minus the GPU.
Build should be designed around the Enthoo evolv Case (Silver Alu or Black / Red) - be it ATX or ITX so very different builds, but love the case so I'm open to both options. Open to X99 or Skylake as well, so gives you a pretty wide canvas.
GPU will be a 1080 added at a later date.
I'm open to Air cooling or AIO. If its an air cooler it has to look nice as well as function.
ideally it will be the following:
Ability to go SLI in the future
If Air cooler, something trick like the AirMaster 8
Black / Red or Black / white build components for colour co-ordination
As quiet yet powerful as possible.
No need to include the following:
Monitor
Keyboard
Mouse
I'll leave the rest to your expertise.
Here are some parts ideas.
Silver/black ATX:
My basket at Overclockers UK:
Total: £1,084.88
(includes shipping: £0.00)
All-black motherboard would do to cut down cost, instead of that Titanium board. Same for the RAM, the Dominator is expensive and other cheaper RAM could be silver/chrome-sprayed for example. 8-Pack chrome painted some stuff on a LAN rig of his last year, and it looked really nice - https://forums.overclockers.co.uk/showthread.php?t=18695265
Black/red/white ATX:
Total: £965.92
X99:
Total: £1,013.91
Don't know if you need Windows, or more storage.
Do you have a gpu you can use for the time being ? Skylake has onboard graphics, but X99 doesn't.
If you are waiting for the custom GTX 1080's then it might be a couple of more weeks after the founders edition.
