Need help in coming up with a spec for the GF, at the moment she's using a laptop with half the keys missing and wants something new.
She's looking to buy a new TV soon and so I was thinking of using her new TV as the new PC monitor also, what features or connections would the TV need for this and is their a simple method for swapping between PC/TV screens.
Also as space is sort of an issue I was thinking of possibly going the Mini-ITX route, it doesn't need to be all that powerful, she'll be mostly web surfing and word processing with the odd low spec game, wireless connectivity is a must though, any features I should look out for in a wireless network card?
Trying to keep to a £250 budget and willing to buy 2nd hand.
Thanks in advance.
Thanks in advance.
hope it helps.. if your willing to buy second hand there are "B" grade parts although these often dont come all the cables etc so its best to buy new if you dont have your own cables at home.
