- 7 Sep 2022
- UK
Hi all,
Need some help to spec a computer for my wife, she needs a PC to run office work, plus some basic photoshop tasks (simple photo enhancements). I usually build my own gaming PCs, so the spec required for something different is confusing me.
Not sure what the GPU requirements would be and if I could get away with the integrated graphics, but I do have an old mini-ITX Sugo SG06B case with 450W PSU that would be great to reuse if possible. The monitor will be a 32" 1440p so needs to be powerful enough for Photoshop on that resolution.
Budget is a low as I can get away with really.
Need spec for;
Motherboard
CPU
GPU (if needed)
Everything else I can work out.
Thanks
Need spec for;
Motherboard
CPU
GPU (if needed)
Thanks
